my 1st Turbo
Also, get a turbo timer so that you can set the car for a certain count down time at idle so you don't have to sit and let it idle for a bit...the turbo timer will shut the car off for you.
You don't really even need to let the car idle after driving it unless you were making boost right up to when you parked or were beating on it within the last couple minutes. When I drive my car regularly, I hardly see boost at all unless I'm trying to get on it, so I don't really need to let itidle,but I also have a larger turbo so it takes a little more to get it going.
Anyways, you need to check your TIMING BELT! If you don't know when it's been replaced last, or youdon't feel you have the experties to deduce that from looking at it, you should replace it.
streetleathal
09-07-2006 02:03 PM
paintballproam
06-22-2006 04:01 PM
