my car is flooding!!!
hello guys,
it was raining like cats and dog the whole night and this morning, when i look under my driver's rubber mat, the was water spot in the car. i tried to figure out how in the world the water could get it since there's no water stains coming from the top. this only happen to the drivers side, not the passenger. i was thinking like maybe it came from underneath but thinking about the logic of it, it seems impossible. any ideas?
RE: my car is flooding!!!
I believe your car was a 97 RS Eclipse. If it is a hard top, maybe it is your seals around your windows. I'm not sure what the seals look like on your car, but they are completely different for the spyder. If you didn't have your window opened a crack, I'm guessing it has to be the seals along the windows. Check those first. If you see any cracks or missing peaces of rubber, then it's the seals. You can use some black silicone RTV sealent to patch up the holes and cracks. Works pretty good.
i will check it out. the weird thing is that even if it is coming from the window, i should have found water dripping from it or even water spots on my seats or on my passenger doors. however, i'll check the window for crack or opening. thanks.
On my 97 talon, i remember right where the drivers side mirror connected to the glass on the window, there was a small leak. Water went straight from there into the window-air vent in the top side of the door or along the inside seam of the door jam. Easiest thing to do is take the hose to it for a mintue or two and see where it leaks.
ORIGINAL: SpyderGS
Same thing on my hard top. Right were the rearview mirror connectd the door to the car. The rubber weather strip doesn't keep a good seal. Try opening your door all the way and then putting the window up all the way then close the door. You will get a better seal than just rolling it up while it is closed.
there was this one time, when the water wasn't completely dried and it started to get below freezing point here in west lafayette, IN. the water froze up and stick my rubber mat to the carpet floor.
