NEED HELP ASAP!!!
well today i am getting a 1998 eclipse gst. 5 speed with a greddy evo 2 cat amd injen intake. i want to know how much boost it pushes stock? and if 15 psi daily is ok on it?. also one more question. whats the max amount of boost i could push without breaking anything?. is maybe 18psi ok for liek a day and then go back down to 15psi?. thank you
RE: NEED HELP ASAP!!!
It's stock, stay at 15psi.
1) The stock 2G bov is plastic and will leak at or around 12psi...the fix is to get a 1G bov and change out the upper intercooler pipe (you'll need to anyway to accomodate the 1G bov). 2) The upgrades mean nothing to performance on their own. 3) Do a complete tune up when buying used from anyone. |
I had more, but the damn board isn't agreeing with something.
Don't go to 18psi for any amount of time because of reason #1...you just can't.
Do a complete tune first before you do anything, then you can do the free upgrades for DSMs. |
ok thank you. what is the stock psi on the 2g ?
I believe its around 12 psi.
ok thank you. wehre is the rechargin hole for the ac? like for the little cans?
Look for the green cap with a "L" on it. It's behind the intake manifold, against the firewall, and close to the AC compressor.
i found it. thanks. i love this car. it is probably the best thing i have ever owned. ill get some pics up soon to show you guys. last question. how do u get ride of the damn car alaram?. something is messed up in the door and everything u open it with the key when its locked it goes off. but the passenger door doesnt do it. so im just going to disconnect it if cut if i have too. where are the wires located? or where could i dosconnect it from easily?
You'll have to unlock the car from the driver's side to disarm the stock alarm when it's armed. The driver's keylock disarms it. It would be easier if you have the keyfob of course.
