-   -   Need Help...correct way to install oil return line gasket (https://mitsubishiforum.com/forum/2nd-generation-63/need-help-correct-way-install-oil-return-line-gasket-16700/)
50ul }{4ck3r Feb 18, 2007 03:33 PM
i need help is this the correct way to install the gasket on the TURBO oil return line
[IMG]local://upfiles/10926/8D5D0B4CF1FB468F943BE7C4D1FC4451.gif[/IMG]
Simss Feb 18, 2007 04:02 PM
RE: Need Help...correct way to install oil return line gasket
well that gasket looks kinda funky, but just tighten it up and it should work i would think.
if you dont feel comfortable with that gaket you could probably get one from the dealership for the stock oil return line which would probably fit better
