need some help quick...
ok i just bought an eclipse and so far wha ive heard the rs's suck which is what i have...but a kid has offered me so a t25 turbo 450 cc injectors 02 houseing stock 2g bov stock upper ic pipe and the intercooler andported slowboyracing manifold for 450 bucks it came off his 95 eagle talon which had the 4g63 can i put it on my 420a?
you CAN run that setup but you'll need a new manifold b/c the 4g63 manifold will not bolt up to your 420a. you will also need a clutch, fuel pump, wideband, tuning device, and tune. after you have all this (aproximatly $1k) you can only run 8-9 lbs. at 10lbs you risk blowing up your motor. so if dropping this kind of money to 1 put your engine at risk and 2 only putting about 200-210whp than go for it. but i personally wouldnt.
wait, what.... buy the 4g63? if you have a 420a and say this.... i just hope youre not thinking of an engine swap, its REALLY REALLY costy to put one in an RS/GS trust Ron and me, we both have and had 420a's hehe
had here. do NOT swap the 4g63t into the 420a you have no idea what you are getting yourself into if this is running through you head. if you look at a 420a the trani is on the right side, if you look at a 4g63 the trani is on the left side. i think you can do the rest of the figuring from there. the cost to swap the engine over is more costly than a GS-T or GSX.
dirtracineclispe
07-12-2006 11:37 AM
1998blackgst 240
04-12-2005 12:56 PM
