no compression
Old Nov 11, 2007 | 08:58 AM
artificialboostin's Avatar
Default no compression
i need help... i bent a valve will driving.... i took the head off n took it to napa for them to inspect it and replace the valve... i put everything back together... go to start it nd it just cranks n cranks n cranks it will not turnovr... i checked all my timing marks nd evryone was perfect... i checked for spark n i have spark... i checked for fuel nd i have fuel... i did a compression test nd had 5 across the board... i need help does nyone kno wat could be going on...
Old Nov 11, 2007 | 09:07 AM
dsm1990gsx's Avatar
Default RE: no compression
You only bent 1 valve? Sounds like your head is trashed. Do a cylinder leak test to see where you have exccesive leakage.
Old Nov 11, 2007 | 11:13 AM
antlip's Avatar
That sounds really odd you only bent 1 single valve while driving. What else happen to the motor?
Old Nov 11, 2007 | 02:22 PM
estraw's Avatar
did you replace the head gasket and torque down the head studs properly?
Old Nov 11, 2007 | 02:25 PM
i took it to napa n the guy replaced the bent valve nd tested the head n it was fine... yes i did replace the head gasket n torque my arp headstuds to spec on the head studs...
Old Nov 11, 2007 | 02:34 PM
dsm1990gsx's Avatar
I still think you have more then one bent valve, there are4 valves for every clyinder, 2 intake and 2 exhaust. If you bent one you should had bent the other one w/ it???
Was the valve guide cracked?
Old Nov 11, 2007 | 02:49 PM
not that i kno of... like the guy at napa pressure tested the head n told me the head is fine... along w the valves
Old Nov 11, 2007 | 02:53 PM
dsm1990gsx's Avatar
Did u check to see if the piston was carcked?
Old Nov 11, 2007 | 03:11 PM
estraw's Avatar
your rings could be shot too
Old Nov 11, 2007 | 03:12 PM
yep everything looked fine... i replaced the stock cams w hks 264 intke n hks 272 exhaust... could that have anything to do w no compression?
