o2 sensor
Old Aug 24, 2006 | 04:30 PM
5Tizzle's Avatar
Default o2 sensor
my rear o2 sensor went out. Im just wondering, if i were to go to a parts yard, would the front o2 sensor be the same thing as the rear one, or are they set up differently? Also would it be different if i were to pull a non turbo front o2 sensor?
Old Aug 24, 2006 | 05:48 PM
DSMTalonAWD51's Avatar
Default RE: o2 sensor
jus go buy a new one, even if its a cheaper no name brand from autozone or something. o2 sensors have sensitive wires, and even if the used one you get it still okay, you may damage it trying to take it off.
Old Aug 24, 2006 | 07:16 PM
5Tizzle's Avatar
well just out of curiousity, are all of those dsm o2 sensors the same anyways? or are they actually set up different?
Old Aug 24, 2006 | 08:54 PM
i think its mostly the length of the wire that changes. I beleive the sensor part itself is the same but the wiring is key, and the harness on it. Like he said go to autozone. I doubt they are more than $50 for a cheap bosch universal one.
Old Aug 25, 2006 | 12:40 AM
gstTurbo2011's Avatar
i went to advanced autoparts a couple weeks ago , and the guy there said for one sensor....****ing 89 bucks...i was like **** that..so i'm just gonna look on ebay
Old Aug 25, 2006 | 05:59 AM
5Tizzle's Avatar
ORIGINAL: TheEngineer
Those cheap ones dont come with the harness. You have to split the wires and use the harness from the broken one. Is it going to work the same?
Old Aug 25, 2006 | 12:19 PM
ORIGINAL: Jeffisdecentttttt
the one that i bought from autozone had the harness on it.
Old Aug 25, 2006 | 01:46 PM
5Tizzle's Avatar
okay ill check into that.
Old Aug 25, 2006 | 01:50 PM
paintballproam's Avatar
i got one from autozone that was a universal for $89 and i had to splice the wires, my dad got a Denso OEM from autozone for $92 and it had a plug. We both did our exhausts a day apart so we needed new ones
Old Aug 25, 2006 | 01:52 PM
5Tizzle's Avatar
did yours work out okay even though you spliced into the wires?
