wing
Old 04-17-2008, 03:19 PM
thecrowforever's Avatar
Default wing
i have the 3pc stock wing on my car now but i want the high wing that most of the turbos come with, now i know i would have to fill some of the holes from the 3 pc but would the high wing fit with the same holes as the 3pc
Old 04-17-2008, 03:22 PM
sk8dudety's Avatar
Default RE: wing
no, sorry man but you'd have to drill new holes
Old 04-17-2008, 08:54 PM
Default RE: wing
yeah, there would be alot of bridge welding to do. The biggest eye sore will be the 2 inch round hole right in the middle of your hatch where your third brake light cable goes through. Pretty big job. Ive done it on acouple of eclipse and talons.
Old 04-17-2008, 09:20 PM
sk8dudety's Avatar
Default RE: wing
i dont think he meant to try to do it without any painting or welding, he meant if the wing would bolt onto the holes on the sides... but would still have to weld up the center hole and quarter panels... the best and easiest way to do it is to put a small piece of metal under the holes and tach weld 'em in, then grind all the welds down and bondo over it... the cleaner you get the welds and the grinding the less bondo you'll have to use, and that less the better, less chance of cracking
Old 04-17-2008, 11:54 PM
Default RE: wing
really, to me the best way, which is what i'm gonna do is just to get the trunk hatch already done like that. try and find one in a junk yard or something.
Old 04-18-2008, 12:27 AM
sk8dudety's Avatar
Default RE: wing
that'd be the easiest, sure, but more expensive... plus you'd have to paint more of it
Old 04-18-2008, 03:05 PM
Default RE: wing
yeah, but easily the best, i mean you could do it the other ways, but i'm lazy and would be glad to pay someone tod o the work for me.
Old 04-18-2008, 04:44 PM
sk8dudety's Avatar
Default RE: wing
yea, and there's a good chance that if you got it from a junk yard you'd get broken glass and have to switch that out... but you might get lucky
Old 04-18-2008, 05:20 PM
shreff99's Avatar
Default RE: wing
Why not run your car wingless? Go for the clean look with some decent wheels. I bet it would look decent.
Old 04-18-2008, 05:41 PM
Kaede.Noir's Avatar
Default RE: wing
then again you'd have to weld in the holes of the 3 piece wing haha
Quick Reply: wing
