po446 CEL
Old Jun 22, 2009 | 12:55 AM
McNeil's Avatar
Default po446 CEL
po446 CEL is on... what could be the cause?
Old Jun 22, 2009 | 06:10 AM
Its ussually something simple like a bad vaccuum line. This has to do with the fuel evaporative system and the charcoal canister. Its either gonna be a bad sensor, clogged line or canister, bad harness to the sensors, or torn vacuum lines.
Old Jun 22, 2009 | 11:20 AM
McNeil's Avatar
well ive checked my vacuum lines.. they all seem good... is the car bad to drive with this code on?
Old Jun 22, 2009 | 12:32 PM
no you should be fine. Its more of an emmission control thing. You wont pass an inspection with it but its fine to drive
Old Jun 22, 2009 | 04:59 PM
McNeil's Avatar
will it definitely not pass inspection? my inspection is up in early 2010... ive checked around online and ive seen it could either be my gas cap or a purge/vent solenoid? is the process of changing these solenoids difficult? thanks for the help i appreciate it
dlx_11
Nov 23, 2012 09:48 AM
mysterio2099
Apr 5, 2006 04:22 PM
brandoN^gsT
Jan 27, 2006 02:36 PM
305RS97
Aug 30, 2005 10:23 PM
mitsu23
Oct 30, 2003 11:56 PM
