-   -   power window (https://mitsubishiforum.com/forum/2nd-generation-63/power-window-19816/)
GANGSTAH33 Jun 16, 2007 02:16 PM
power window
i have a ques my driver window doesnt work from the master switch but my passenger does besides the relay does it or does it now have a circuit breaker and if where is it located what might be some of the problems to look out for i checked all the wires none of them are damaged
I Drive Naked Jun 16, 2007 02:57 PM
RE: power window
Check for continuity at the switch, and if you have power/ground, then pull off your door panel and check for power and ground at the window motor.
Unplug the motor then plug in the switch.
with your test light touching the contacts, operate the switch, if no power to the window motor, you have a bad switch.
But if you're getting power to the motor, then you looking at a bad window motor.
Dusty Eclipse Jun 16, 2007 03:40 PM
RE: power window
Its more than likely the motor... assuming I understood that...
GANGSTAH33 Jun 16, 2007 11:23 PM
RE: power window
well i already did all that check for continuity at the switch i even had a spair switch and window motor did not work and due to the wiring diagram it says it has a circuit breaker but i cant find it now im new to this electrical im trying to master it but when i probe the power window control module the white wire with a self powered test light then the window goes up and down and the test light lights up
