problem
i just had the ssqv bov istalled today, it sounds awsome but now the check engine light came on, car just has full hks cat back, its automatic and everything else is stock with 70k miles, any help?
RE: problem
your BOV is venting to the Atmosphere, your losing air that the motor thinks it is getting so the light is on... and the car probly has a bouncing idle its and auto so no stumble between gear shifts but either way that is the problem I can almost garentee it;)
RE: problem
thanks, so what do i do about it take the bov off or leave it and it will be fine? can it cause any problems?
RE: problem
ORIGINAL: Jeff822 thanks, so what do i do about it take the bov off or leave it and it will be fine? can it cause any problems? |
RE: problem
ok, thanks a lot man, do u know where i can get the recirculation kit at? right from HKS?
| All times are GMT -5. The time now is 10:22 AM. |
