PROBLEMs help
Hye guys i have a few probs jsut need imput on. First my horn doesn't work. 2nd the acuators for the trunk don't work and only sometimes they do, third the person i bought it from moved the windsheild wiper resevior, so i was wondering how i could fix these and if someone could tell me where the resevior goes, also the windsheld does the spray only for the back even whenever i press either the back one or the front one it will jsut do the back thanks
im me at imapirate30 if you need to email me at imapriate30@yahoo.com |
RE: PROBLEMs help
Try cleaning the horn contacts, i did and it helped. The trunk actuators are gonna need to be replaced. I stil lhaven't done that. and the reservoir should be in the sill where your trunk comes down. I hope this is right lol
RE: PROBLEMs help
Read the sticky on fixing the horn. Ive done it and it works perfect, and is really easy to do.
Yourtrunk shocks are dead, andcan only be fixedby replacing them Where did he move thereservoir to? If you have a 95-99, it should be below your spare tire beneath the hatch. |
RE: PROBLEMs help
If you take your back panels off in your trunk you will see the fluid hose going down. Follow it untill you find the reservoir. If its gone completely then when you fill it up with fluid, it will be going right into your trunk and collect down by your spare..
