Problems with my automatic transmission on eclipse spyder -96
Hello!
I have an importet Mitsubishi Eclipse GS Spyder 2.0 automatic -96 it comes from californien. Now it belongs to med in Sweden. When i bought it it works fine in but after a week the automatic transmission it startet to freak out. from perfectly working to not work at all it took 7 minutes. We have tried to change oilfilter and all the transmission oil 3 times. After the 2 first times it work perfectly on all gears. but now it works fine on 1,2 and going backwords. When it comes to the third gear it goes in but secons after it jumps out and it is like when ju press down a clutch on a manual car but still gives gas. so the big problem is that it works perfect on 1,2 and rear but the 3 gear doesn´t want to work for longer than about 3 seconds. Any idé? HELP! Every idé is good! Now when the sun is shining in Sweden you do want it to work... THANKS EVERYONE! |
RE: Problems with my automatic transmission on eclipse spyder -96
Anyone?
| All times are GMT -5. The time now is 10:28 AM. |
