Projector headlights - fuse blowing
ok basically what you do with a switch.. is you uhm... the switch is suppossedly cutting the power cable in two.. by either actually cutting it, or getting a wire to the switch and then connect the power cable into the switch... the idea is that the switch interrupts the current
no, you ground one red wire, run the other one to one end of the switch, and the other end of the switch you run to ur fuseblock under ur dash. i chose a fuse that had constant power, that way i could turn them on at a car show without leaving my car on
