psi Qustion help please
Old Sep 18, 2006 | 10:08 PM
99blake's Avatar
Default psi Qustion help please
how much psi or boost can I run to 420A eclipse motor please help.
Old Sep 18, 2006 | 10:09 PM
gstTurbo2011's Avatar
Default RE: psi Qustion help please
what supporting mods do you have, fuel pump, injectors, intercooler?
Old Sep 18, 2006 | 10:14 PM
estraw's Avatar
i think its about 8-10 psi safely. 12 is when you'll start running into problems.
Old Sep 18, 2006 | 10:46 PM
slow420a's Avatar
ORIGINAL: estraw
*** we have a winner, 12psi=blow rings. For more info check the stickys, after that if your head is still spinning pm me.
Old Sep 19, 2006 | 01:37 AM
99blake's Avatar
10 psi is safe on my engine.
Old Sep 19, 2006 | 02:28 AM
davidmitsusrock's Avatar
^thats what i was thinking. wouldnt go much past it though
Old Sep 19, 2006 | 09:25 AM
its really depends on all the mods you have. First your gonna need fuel to do the turbo i believe. Then i think its like 5 or 6psi non-intercooled. Then like they said 10psi on the stock internals. Build up the internals and pretty much the engine could handle almost as much as you can throw at it.
Old Sep 19, 2006 | 05:41 PM
slow420a's Avatar
ORIGINAL: TheEngineer
The 420a cant hold a headgasket past 30psi for some reason. Shawn from CI was running 32psi and was blowing one every other week. The only thing to do after that is o-ring the block/head.
Old Sep 19, 2006 | 09:37 PM
estraw's Avatar
wow, you gotta be nuts to pump 32 psi into a chrysler motor
Old Sep 20, 2006 | 12:43 AM
slow420a's Avatar
ORIGINAL: estraw
ya guy isant wrpped so tight
