random miss
when my gst is at idle it has just started missing evry randomly some times it dose not outher times it dose do yall have any thoughts on what the problem might be
RE: random miss
does it do it under a load? like when you give it gas? if so then i'd say change your plugs and wires... if not and it just does it at idle, i'd say that you'd have a vacuum leak somewhere. trace it, you maybe able to hear a hissing under the engine compartment from that leaking vacuum hose
RE: random miss
NGK Plugs (not iridium) and OEM wires : )
RE: random miss
its not the plugs or wires there both only a month old ill check for the vacume leak'
RE: random miss
I wouldnt say that. What did you replace them with?
RE: random miss
taylor 10.4 mm race wires with ngk 1step colder plugs
RE: random miss
Those plugs gaped right?
The wires more than likely suck..regardless what you paid for them. |
RE: random miss
the wries dont suck there the same wires that my dad pro gas darg car runs
RE: random miss
Okay : )
Then i say you just need to gap em |
RE: random miss
they have the correct gap
