-   -   Replaceing Radiator Support? (https://mitsubishiforum.com/forum/2nd-generation-63/replaceing-radiator-support-19401/)
thehintons06 May 31, 2007 11:09 AM
Hi i bought a eclipse gs that has front end damage and one of the things i will need to replace is the radiator support. I was wondering if yo u know of anyplaces that have how to's on how to do this or if you could tell me how to do this. I have never welded before and need to know where to weld and where to cut the old support off at. i am mechanicaly inclined so i can handle this project i just need a how to .
thanks a million
Brandon
sk8dudety May 31, 2007 11:12 AM
RE: Replaceing Radiator Support?
if you've never welded before then i would not suggest welding onto ur core support for a test run... i would suggest getting it done somewhere or having someone you know that can weld do it for you... as far as the how-to... all you have to do is get the part, see where it is welded onto from the factory, cut that piece out, and weld the new on back into place
RCJr9186 May 31, 2007 02:19 PM
a good place for "how to's" is a haynes manual or a chilton's manual. you can get both or either from any advanced auto or atuo zone.
