running rich
Old Mar 15, 2007 | 10:38 PM
sprtcarmaniak's Avatar
Default running rich
i know white smoke= runing to rich.. i dont have the money for an afc.. but there is someone that will usean afc on my car and then take it off after he tunes it.. will that fix the problem for running rich??? or do i need to buy and afc??
Old Mar 15, 2007 | 10:50 PM
Default RE: running rich
the AFC cant tunethe ECU.. it fools the ECU so in other words you cant tune it then take it out it needs to stay in there. taking it out puts the car back to stock
Old Mar 15, 2007 | 10:55 PM
oh. thanks.. the guy said he could put his afc to it and fix the problem... thanks.. so what should i do???
Old Mar 15, 2007 | 11:03 PM
Well lets start by finding out why your running rich... cause it shouldnt run crazy rich unless you have a TON of mods then something is wrong prob. if your onstock fuel esspeically
Old Mar 15, 2007 | 11:10 PM
do you mean stock(fuel) injectors, rail, pump??? those kinda things???
Old Mar 15, 2007 | 11:13 PM
yes exactly. What parts have been upgraded so far.
Old Mar 15, 2007 | 11:27 PM
and when did the problem start
Old Mar 16, 2007 | 10:38 AM
RCJr9186's Avatar
and you say it's white smoke? smell it, what does it smell like? check your coolant level.
Old Mar 17, 2007 | 04:12 PM
DSMTalonAWD51's Avatar
ORIGINAL: RCJr9186
yep. white = lean and/or coolant aka quite possibly your head gasket is gone. run a compression test.
black = rich. pull your plugs an check em out too
austinw23
May 2, 2007 06:49 PM
racerx55
1st Generation
Feb 25, 2007 06:59 AM
DixonsGst
Jan 27, 2007 07:21 PM
mtalma
Nov 13, 2006 10:34 AM
My93EclipseGS
1st Generation
Apr 14, 2006 06:53 PM
