running rich
i know white smoke= runing to rich.. i dont have the money for an afc.. but there is someone that will usean afc on my car and then take it off after he tunes it.. will that fix the problem for running rich??? or do i need to buy and afc??
RE: running rich
the AFC cant tunethe ECU.. it fools the ECU so in other words you cant tune it then take it out it needs to stay in there. taking it out puts the car back to stock
RE: running rich
oh. thanks.. the guy said he could put his afc to it and fix the problem... thanks.. so what should i do???
RE: running rich
Well lets start by finding out why your running rich... cause it shouldnt run crazy rich unless you have a TON of mods then something is wrong prob. if your onstock fuel esspeically
RE: running rich
do you mean stock(fuel) injectors, rail, pump??? those kinda things???
RE: running rich
yes exactly. What parts have been upgraded so far.
RE: running rich
and when did the problem start
RE: running rich
and you say it's white smoke? smell it, what does it smell like? check your coolant level.
RE: running rich
ORIGINAL: RCJr9186 and you say it's white smoke? smell it, what does it smell like? check your coolant level. black = rich. pull your plugs an check em out too |
| All times are GMT -5. The time now is 09:18 AM. |
