safc! :(
Old Oct 10, 2009 | 09:57 PM
c577's Avatar
Default safc! :(
i just installed my afc according to the 2g directions on vfaq, except the misleading info about the maf sensor wires (tells wrong colors). and the "ECU pinouts for 2G turbos" on vfaq also. but my afc isnt working properly, the lights on the buttons come on but they are very dim, and the screen wont come on at all. i quadrouple checked all of the wires and they are all good, including the two grounds and i know that the brown is supposed to be closer than the black which it was. it is installed perfectly i checked all connections and it just wont come on. is there anything i can do to check and see if it is broken because this was bought used from ebay and if it is then i can send it back i think...
Old Oct 11, 2009 | 08:35 AM
dsm1990gsx's Avatar
Does anything come on besides the back lighting?
Old Oct 11, 2009 | 12:15 PM
c577's Avatar
just the light on the buttons, nothing else comes on and those lights are very dim
Old Oct 11, 2009 | 02:53 PM
dsm1990gsx's Avatar
Do you have a dvom? Check to see what kind of voltage your getting at the power wire.
Old Oct 11, 2009 | 10:06 PM
c577's Avatar
what is a dvom?
Old Oct 11, 2009 | 10:07 PM
c577's Avatar
oh two more questions, 1. do i have to use the power from the computer or can i run a wire from the battery through a fuse, if so, what size wire/fuse. 2. why does the black ground have to be farther from the brown ground? isnt a ground a ground? it just doesnt make much sense to me that one would have to be farther from the other
Old Oct 11, 2009 | 10:48 PM
dsm1990gsx's Avatar
Originally Posted by c577
what is a dvom?
Digital volt ohms multimeter
Old Oct 11, 2009 | 10:49 PM
dsm1990gsx's Avatar
I used the red power wire going to the ecu. The ground thing I have no idea lol.
Old Oct 12, 2009 | 09:13 PM
c577's Avatar
i do have one but im not quite sure what i should be using it for lol i always just used it to make sure that something was getting power, never how much power it is getting. and i think i am going to take it to an electronics shop tomorrow and see what they can tell me, they wont be able to hook it up to a rpm sensor and all that lol but they can hook it up to power and ground and see whats up
Old Oct 15, 2009 | 07:07 AM
oh_what_up's Avatar
The two grounds are offset because of the flow characteristics of electrons. Electrons actually flow from the negative terminal of the battery to the positive terminal, due to their electric charge. With one ground being offset from the other, depending on the direction of the flow of electrons, one ground gets electrons first, most likely to power the unit, and then the other gets electrons second, possibly to amplify the signal to the computer. Electron flow is very fast (don't feel like looking up its actual speed right now), so within our understanding of time, the grounds gain electrons almost instaneously. I hope that helps. Have a good one
92_laser
1st Generation
Jan 22, 2006 03:15 PM
antlip
Dec 27, 2005 08:44 PM
chrispimpryan86
Dec 8, 2005 12:26 AM
16psi eclipse
Oct 1, 2005 01:51 PM
1320a
Mar 6, 2005 10:00 PM
