the smoke out...
Old Apr 18, 2007 | 12:44 AM
sprtcarmaniak's Avatar
Default the smoke out...
well i have a 95 gst.. with a rebuilt engine.. and it had about 100k before i rebuilt it.. so when i get on it hard, it smokes (dark gray) when i shift but only when i shift.. what is it??? the turbo seals??? just an old turbo and need to be rebuilt???
Old Apr 18, 2007 | 01:01 AM
Default RE: the smoke out...
Its normal bro relax
Old Apr 18, 2007 | 01:53 AM
darknigh7th's Avatar
it happens once in a while, just be happy its not white smoke.
Old Apr 18, 2007 | 02:20 AM
2nd g eclipse gst's Avatar
so what does it mean when its white smoke
Old Apr 18, 2007 | 02:21 AM
Means coolant... usually that means headgasket
Old Apr 18, 2007 | 02:30 AM
**** guys my car is starting to smoke but only when i hit the gas and alittle bit after that but it stop until i hit the gas again any thoughts
Old Apr 18, 2007 | 02:36 AM
White? Blue? Black?
Old Apr 18, 2007 | 02:39 AM
dang man it looks white
Old Apr 18, 2007 | 02:42 AM
Coolant gettin into the combustion chamber... your lookin at a head gasket bro. Take a look under your oil cap and see if you see white ****.
Old Apr 18, 2007 | 02:59 AM
put on a good head gasket if you need to replace it, put some good head studs etc etc.
