-   -   the smoke out... (https://mitsubishiforum.com/forum/2nd-generation-63/smoke-out-18143/)
sprtcarmaniak Apr 18, 2007 12:44 AM
the smoke out...
well i have a 95 gst.. with a rebuilt engine.. and it had about 100k before i rebuilt it.. so when i get on it hard, it smokes (dark gray) when i shift but only when i shift.. what is it??? the turbo seals??? just an old turbo and need to be rebuilt???
Sebba Apr 18, 2007 01:01 AM
RE: the smoke out...
Its normal bro relax
darknigh7th Apr 18, 2007 01:53 AM
it happens once in a while, just be happy its not white smoke.
2nd g eclipse gst Apr 18, 2007 02:20 AM
so what does it mean when its white smoke
Sebba Apr 18, 2007 02:21 AM
Means coolant... usually that means headgasket
2nd g eclipse gst Apr 18, 2007 02:30 AM
**** guys my car is starting to smoke but only when i hit the gas and alittle bit after that but it stop until i hit the gas again any thoughts
Sebba Apr 18, 2007 02:36 AM
White? Blue? Black?
2nd g eclipse gst Apr 18, 2007 02:39 AM
dang man it looks white
Sebba Apr 18, 2007 02:42 AM
Coolant gettin into the combustion chamber... your lookin at a head gasket bro. Take a look under your oil cap and see if you see white ****.
darknigh7th Apr 18, 2007 02:59 AM
put on a good head gasket if you need to replace it, put some good head studs etc etc.
