so another problem with my 4g63
ok, i put the intake manifold gasket in, got everything nice and tight, hooked everything back up right. fixed my throttle body cable, i let it get too loose by the way, went to go start it. It starts up, idles like **** and then dies on me, and after that i hear this big woosh sound of air coming from the motor, i haven't found out exactly where yet, but i will start looking friday, any ideas for the time being?
RE: so another problem with my 4g63
First off check the IAS setting, secong check/change the PCV valve, 3rd check the PCV valve's hose. With the stuff you've done that sounds like a logical place to start in my opinion.
yea tune up your idle set screw, does the car idle high then dip low then higher then lower? it might be a leak somewhere lower in the intake, but for the most part just turn your idle up some and you should be fine
well it starts up fine, then when it goes to idle, it sounds rough, and it starts to die.. the rotations get slower and slower until it dies. I've turned the idle screw some and it has no change at all. I get this loud swoosh air sound somewhere, i'm gonna try to see if a vacuum hose is disconnected or leaking. But when it does run for the few seconds the gasket definately fixed my vacuum leak, now i have another one somewhere.
Sir gud day to all of you! Can somebody please post a picture of 4g63 engines AIC location, I'm so confused finding it in the TB, is it under facing the firewall or the one in front of it with two adjustable screw facing the front? Thank you and more power!!! you can also email it at francislllchua@yahoo.com
mco
01-31-2012 09:42 AM
