spark plugs and wires
what spark plugs would you guys suggest for my car,and i have the stock wires if i upgraded would it make a difference?and if so what wires are the best?
RE: spark plugs and wires
NGK all the way! the regular ones are fine.
X2 for NGK's
what about ignition wires?
I'm pretty sure the OEM wires are good
NGKS again. Im running magnacore 8.5 mm wires and have had no problems.
ORIGINAL: antlip NGKS again. Im running magnacore 8.5 mm wires and have had no problems. |
yea i just replaced mine not too long ago... got the NGK iridium (spelling??) and oem wires from napa... it's workin just fine!
Accel wires...The next best thing to MSD (which btw has issues in DSMs).
The Answer to Spark Plug Wires ( Ignition Wires ) [/align] [hr] This is to help all those looking to upgrade their ignition wires and are not sure what brand they would like to buy. The following is the resistance measured in ohms/ft by each major ignition wire distributer. (low = good, high = bad) MSD Ignition 8.5mm Super Conductor (40-50 ohms/ft) Accel Thundersport (150 ohms/ft) Taylor 8mm Spiro Pro (350 ohm/ft) Aurora ignition wire set (400 ohms/ft) Vitek Performance Cables (their web site does not mention resistance, but John Monnin measured them at about 800 ohms/ft; the label under Vitek's braiding says "Magstar Gold 8mm High Performance S-4 Stainless Steel Mag Wire" - thanks John!; Magstar wires are manufactured by Wiretec) Wiretec Magstar Gold (800 ohms/ft as measured by John Monnin) NGK Resistor Spark Plug Wire Set (2600 ohms/ft) Mitsubishi factory wire sets (3000++ ohms/ft) Car Quest brand wire sets (3000++ ohms/ft - Thanks to Bret for measuring these wires.) Magnecor KV85 (6000++ ohms/ft)[/align] |
What kind of issues does msd has on the dsm silver?
