srs light
Old Oct 16, 2005 | 01:58 PM
pink_eclipsechic's Avatar
Default srs light
whenever i turn my car on the SRS light turns on and makes a beeping noise it usually turns off but it didnt the one time. Whats the SRS light anyway?????
Old Oct 16, 2005 | 02:20 PM
Lil red's Avatar
Default RE: srs light
Suplemental Restraint system... Your airbag system
Old Oct 16, 2005 | 02:54 PM
lol ok thanks, i had no idea intill now.
Old Oct 16, 2005 | 04:34 PM
Sanguinius's Avatar
If it stays on any more you MIHGT wanna get that checked. Might have a problem with the airbag system.
Old Oct 16, 2005 | 08:27 PM
Joel_CA's Avatar
Any other information would be helpful (model year, etc)
Joel, CA
Old Oct 16, 2005 | 10:14 PM
ORIGINAL: Joel_CA
Joel, CA
Why do you need to know this?? SRS is the air bags non the less.
Old Oct 18, 2005 | 09:12 AM
i have a 99 eclipse gs why?
Old Oct 19, 2005 | 12:41 AM
Joel_CA's Avatar
Geez... no kidding smart a$$. Simple questions require a simple answer- that all. Having worked for Mitsu for several years, there are pattern failures that can be picked up on that i could share based on the requested info. Such as that 02 Eclipse that you traded. VERY HIGH failure rate on the side airbags. Enough for them to write a TSB about it.
As for the 99's (thank you for your clarification)- you'll need to have the exact DTC read from the SRS ECU. Not sure if any aftermarket scan tools can do this (perhaps the Snap On scanner with SRS cartridge can), but this will pretty much narrow it down to what the source problem is occuring (but still needs to be verified with a little testing). Could be anything from an actual impact sensor, clock spring, or even an airbag.
Joel, CA
Old Oct 19, 2005 | 05:50 PM
thank you for ur help as of now the light goes off so i think im in the clear for now, thanks again!!!
Old Mar 29, 2006 | 09:17 AM
warnox's Avatar
Hey!
OK have a 98' Lancer SEi Limited, Right hand drive, auto, 1.8L! The SRS light is on, it came on a year or 2 ago and got it fixed, cost heaps coz they changed something in the steering wheel, this was at the mitsubishi dealership! Anyone have any idea what this might be again?
Thnx in advance...
