srs light
whenever i turn my car on the SRS light turns on and makes a beeping noise it usually turns off but it didnt the one time. Whats the SRS light anyway?????
RE: srs light
Suplemental Restraint system... Your airbag system
RE: srs light
lol ok thanks, i had no idea intill now.
RE: srs light
If it stays on any more you MIHGT wanna get that checked. Might have a problem with the airbag system.
RE: srs light
Any other information would be helpful (model year, etc) :eek:
Joel, CA |
RE: srs light
ORIGINAL: Joel_CA Any other information would be helpful (model year, etc) :eek: Joel, CA |
RE: srs light
i have a 99 eclipse gs why?
RE: srs light
Why do you need to know this?? SRS is the air bags non the less. Geez... no kidding smart a$$. Simple questions require a simple answer- that all. Having worked for Mitsu for several years, there are pattern failures that can be picked up on that i could share based on the requested info. Such as that 02 Eclipse that you traded. VERY HIGH failure rate on the side airbags. Enough for them to write a TSB about it. As for the 99's (thank you for your clarification)- you'll need to have the exact DTC read from the SRS ECU. Not sure if any aftermarket scan tools can do this (perhaps the Snap On scanner with SRS cartridge can), but this will pretty much narrow it down to what the source problem is occuring (but still needs to be verified with a little testing). Could be anything from an actual impact sensor, clock spring, or even an airbag. Joel, CA |
RE: srs light
thank you for ur help as of now the light goes off so i think im in the clear for now, thanks again!!!:)
RE: srs light
Hey!
OK have a 98' Lancer SEi Limited, Right hand drive, auto, 1.8L! The SRS light is on, it came on a year or 2 ago and got it fixed, cost heaps coz they changed something in the steering wheel, this was at the mitsubishi dealership! Anyone have any idea what this might be again? Thnx in advance... |
| All times are GMT -5. The time now is 09:49 AM. |
