Stalling in the rain
Old 06-27-2006 | 01:46 PM
publicgrace's Avatar
Default RE: Stalling in the rain
I will definately check and let you know.
Old 06-27-2006 | 01:47 PM
No I don't have a big blue pipe on top of my engine.
Old 06-27-2006 | 01:48 PM
so what do you have. Near the front of the engine bay do you just have a big black air box?
Old 06-27-2006 | 01:53 PM
I'm gonna take some pictures and look around the inside and then I'll get back to you with some answers...I feel like such a dummy. I'll do it today after work.
Old 06-27-2006 | 05:23 PM
I know why it is. Its because of humidity stoping the electric current going from the plug wires correctly. If you look very closely you may even be able to see it arcing. One woman on here before had this problem. I still dont know how she fixed it. But if you find where it is arcing then my recomendation would be to spray it with some kind of synthetic spray to repell any kind of moisture. Hope that helps!
Old 06-29-2006 | 01:23 PM
N/Teclipse's Avatar
They make a gell that you put on the end of the spark plug and you can get it at any car parts store. Plus if you decided to buy new wires most companies now put that already in the boot of the wire.
Old 06-29-2006 | 02:45 PM
slow420a's Avatar
Electrical contact silicone, wd40, or crc 656 dry lubercant will inhibit moisture. That cel is a clue to the cause. when you key up the motor that light comes on to show that the ecu is getting power. So you have a short some where but it lies with the power for the ecu. Check all of your leads for cracked wires or bad grounds.
Old 07-09-2006 | 12:42 AM
Hi all...it took me a while but I finally got the pictures of my engine up. I hope this makes things easier to explain and for me to understand.
http://www.premiermeg.com/eclipse.htm
Old 07-10-2006 | 03:04 AM
Don't forget me
Old 07-10-2006 | 09:33 AM
people have given you some answers to look into already, check your wiring as they have said
Quick Reply: Stalling in the rain
