Starting Problems
RE: Starting Problems
Well the new throttle body isint the problem.... Im thinking either Sebba is right with the coilpack, or i could have a vacumm leak. Sounds like a vacumm leak to me... i dunno cold start vacumm is there, after i shut it off once warmed then right back up - vacumm is there. If i leave it sit.... Vacumm could have leaked causing hard start. The hoses could have expanded?? causing lose of pressure?? i dunno ... im about over it.
You could be losing fuel pressure. The expanding rubber vacuum hose theory sounds rational to me. It could be anywhere or anything concerning the fuel system though. Spark, fuel, and air...which one of these aren't you getting? Spark was stated as fine (minus possible coilpack, which should be resistance checked btw), air seems good (check all air lines anyway), and fuel hasn't yet been checked (and all of it's components).
