Stupid Mitsubishi
Hey I have this crappy car and the C.E lightis onand thecode was for being too lean. But when I have Mitsubishi check it they tell me that the problem is a cracked exhaust manifold. Now when I ask them if replace it will the car run right? "Only if that isthe only thing wrong with it" the dumbass replied. How the hell does exhaust cause a car to run lean?
RE: Stupid Mitsubishi
If the manifold is cracked, oxygen is gonna go into the exhaust and the o2 sensors and going to pick it up and read lean.
Then would it also be causing the car to run like crap?
Yep, my old 1gen had a cracked manifold and it would stall when it was completely warmed up. I fixed the crack and my symptoms went away.
ORIGINAL: asphalt_pimp Hey I have this crappy car and the C.E lightis onand thecode was for being too lean. But when I have Mitsubishi check it they tell me that the problem is a cracked exhaust manifold. Now when I ask them if replace it will the car run right? "Only if that isthe only thing wrong with it" the dumbass replied. How the hell does exhaust cause a car to run lean? Yes, if the front o2 sensor is reading lean, the computer tries to compensate by adding more fuel, your MPG deteriorates, your car runs bad. So, it's really not a dumbass answer, just a general answer and unless, you pay for it, that's usually all they're going to give bro. They have to make money somehow. |
