-   -   sunroof wont shut (https://mitsubishiforum.com/forum/2nd-generation-63/sunroof-wont-shut-4013/)
jeepstud Apr 16, 2005 12:04 AM
sunroof wont shut
I dont know whats wrong. My sunroof wont shut, I have checked the fuse. Is this a common problem. Can the dealer check the switch. where is the sunroof motor located? How do I get to it? Is there any way to manually close it?
It is a 2000.
wicked_outlander Apr 16, 2005 12:11 AM
RE: sunroof wont shut
better check w/ the dealer.....its a pain in a butt.
DSMTalonAWD51 Apr 16, 2005 12:48 PM
unscrew the glass piece from underneath (3 bolts on each side) and try to close it with out that in the way. you can watch all the mechanisms and try to give it a little "boost" to find the problem
get435 Apr 16, 2005 07:05 PM
if it wont shut at all sounds like you blew a relay.
jeepstud Apr 16, 2005 09:24 PM
anyone know where the relay is at so I can check that?
