t-25 turbo?
Getting a boost controler with out a boost gauge is the stupidity at its finest. A boost gauge at auto zone will go for 60 bucks, faze i think, Then all you need is a place to mout it, there is a way to put in in your door vent, and its pretty cool looking for dam near free. Ill throw the diy up if i can find it
hell yea that diy would be sweet! Autozone is were i was planning on getting one. They are faze. I used to work there and still get 20% discount. Im thinking i just run it off of the middle throttle body line correct me if im wrong.
http://www.2g nt.com/www/corbin/boost.html for the link to work your going to have to remove the space between the 2g and nt. the dircetions are pretty simple and personally i think it looks pretty good. Only bad thing is that you can no longer have heat or ac to that area.
NO offense but buying a boost controller without a boost guage really is not a good idea and is an easy way to break something. But no your turbo is not maxed out my guess is youll be running between 10-12 PSI stock and I have seen some 2Gers running as high as 16 on stock fuel. an extra 4-6PSI will make a difference but shortly after that you are pushing the turbo behond it efficientcy range and it will just be nothing more than a hair drier. thats when the 16G upgrade comes into play ...or even a 14B if you only want a minor adjustment but to me that is a waiste of time.
