Throttle body difference
Old 06-28-2006, 03:35 AM
Nubiebubie_GSX's Avatar
Default Throttle body difference
Is there a difference between the automatic 2nd gen eclipse throttle body compared to the 2nd gen manual. Just that i don twant to buy it if its different. Somebody having a garage sale and i saw it, but it was takin from a auto eclipse. I wouldn't replace it but mine causes my gas pedal to stick.
Old 06-28-2006, 05:31 AM
Default RE: Throttle body difference
Um, nope...the only difference is the tranny...TB's, as weel as all engine components, are the same...what model are you looking at?
RS, GS, GS-T or GSX???
Old 06-28-2006, 07:00 AM
well i have a 98 GSX and the part i was lookin is a 95 GSX
Old 06-28-2006, 09:25 AM
From what I have seen of the GSX, mine in particular, there really isn't that much of a difference....engine wise of course. The TB should be the same...the only thing I have heard about throttle bodies is a ported 1st gen to allow a better flow. Other than that, same old thing.
Old 06-28-2006, 11:25 AM
RCJr9186's Avatar
no difference, but why would you want a second throttle body? you can take it to a shop and have them port it into like a 60mm if you want but it's really not something you need to have in reserve...
Old 06-28-2006, 12:34 PM
ORIGINAL: RCJr9186
he said the one he had is sticking
Old 06-28-2006, 01:21 PM
RCJr9186's Avatar
HA HA just kidding!! one of those days....
Old 06-28-2006, 02:04 PM
ORIGINAL: RCJr9186
Old 06-28-2006, 05:56 PM
Well its installed and working, but there a few minor things. The idle fluctuates alot, I adjusted the Biss screw by just turning it. Idle around 750-850. But at one point i got a idle control malfunction and i stalled it a few times. Also 1st gear seem to be so sensitive now. I left my foot on the gas and didn't move it and the car was jerkin and the rpm fluctuated. Thinking of adjusting the TPS that on there. Would that help.
Old 06-29-2006, 10:38 AM
if the rpms are searching then i think you might have a leak somewhere
Quick Reply: Throttle body difference
