timing belt
i just did mine timing belt and now my car only idels about 100 rpms could this be beacuse i have the timing of one notch because when i changed it it looked like there were to marks on the crank shaft. i have all of the marks at tdc except for the crank i am just guessing that the big notch is the tdc mark anybody know what i am talking about
o and a picture of what that mark might look like if anybodys got it |
RE: timing belt
If you go to vfaq.com they have a complete wirte up w/ pics. If the timing is off 1 tooth you'll have a rough idle.
RE: timing belt
so if i change it would that fix the problem
RE: timing belt
It sounds like your timing is off, I would reccomend checking all of your timing marks (CAMs, crank, balance shaft) if you only did your timing belt then that Has to be the problem
RE: timing belt
ORIGINAL: dorian7 It sounds like your timing is off, I would reccomend checking all of your timing marks (CAMs, crank, balance shaft) if you only did your timing belt then that Has to be the problem |
RE: timing belt
With the crank, its actually on that metal plate behind the gear..
RE: timing belt
well when i did it my head gasket was leaking so i figured while i was there i would replace the timing belt water pump and balence shaft belt( which was actually all f'ed up in there) i know the head gasket isnt leaking so if it was off on mark that would cause it to run at low rpms. i know when i set it up the cams, bal saf, and oil was all lined up perfectaly but the crank i couldnt figure out.
RE: timing belt
I would most definently not run the car ANYMORE if you have no idea where the balence shaft is in terms of timing. Look on that Vfaq page and pick up a repair manual at the auto parts store. All of the timings HAVE to be perfect.
RE: timing belt
Can you post pics of the timing marks on the timing belt and balance shaft belt? You probably have the b/s off. And just like dorian7 said checkvfaq.com and make sure you have the b/s timed right and not off 180*.
| All times are GMT -5. The time now is 05:16 AM. |
