Trouble Codes - Need Advice
Old Nov 17, 2014 | 07:51 AM
iceman31's Avatar
Default Trouble Codes - Need Advice
My sons 99 GS has thrown a few codes: Your advice would be greatly appreciated.
P1767 & P0700 which are related codes: I am looking to start with the simple stuff so I want to change the EATX Relay. I can not find this relay anywhere online - the part # I got off the relay itself is this 04687146A 68832 2308. Is this a special relay? Is there any trick to changing it out? I removed the bracket with all three relays on it and it looks like it is clipped on somehow.
P0551 - Power steering pressure sensor switch. Not sure how to fix this? I pulled the hose off the unit and cleaned it up a bit as it looked dirty, the hose also has a bit of a kink in it so maybe that is what is causing the code to be thrown.
P0141 - Not really worried about this one yet as it is the rear O2 sensor.
Car seems to run fine but these codes keep popping up and I want to make them go away.
Thanks in advance.
beetlenut
Jan 22, 2017 06:11 AM
Davie-h
Nov 11, 2013 01:25 PM
membreya
Apr 18, 2013 12:50 AM
doubler
Mar 29, 2009 03:23 PM
knifemaker
1st Generation
Sep 7, 2007 06:21 PM
