tuning.. GSX???
tuning.. GSX???
ok, so... we all know the gsx is tuned for a turbo... but what happens when you upgrade the old turbo to a larger more powerful turbo?... should you retune the gsx? if sooo... do you need a new system.. or can you just take it to a tuning shop and they will do it for you?
so i guess what im asking, is the stock gsx capable of being tuned for a larger turbo?
thanks
Scotty*
thanks
Scotty*
RE: tuning.. GSX???
You don't always need to do fuel mods.
Now, if you want to run more boost with that bigger turbo, then you will need fuel mods, and something to tune with.
If you are going for bigger than a 16g, then I say get DSMLink.
RE: tuning.. GSX???
ORIGINAL: dsm1990gsx
More air you want more fuel.
ORIGINAL: Sebba
More volume of air = more power.
RE: tuning.. GSX???
ORIGINAL: Sebba
No ****??? The stock fuel system can handle a little more fuel. You can run a 16g at 12psi just fine.
RE: tuning.. GSX???
Id say get a DSM link (Not needed completely for this turbo, but comes in handy...best tuning system for a dsm. if your buying a tuning device might as well go with this) with some new injectors and a fuel pump. I think that should be good for a 16g if that's what your going to be running, anything bigger you'll want to upgrade more, but what is it your going to run? and if I made a mistake please correct me.
