Turbo next? Give me your opinion
RE: Turbo next? Give me your opinion
YES GET A BOOST GUAGE. NEVER trust factory guage. Also GET BIGGER INJECTORS!! With stockers you'll be coming clos to maxing them quite a bit and what happens when you max a valve and try to force it even wider open? Other than running lean cuz you're not getting enough gas you'll also eventually start getting injectors sticking. Leading to rich at low boost lean at high boost. Then all SORTS of evil bad problems crop up. Cuz now you have some cylinders running at the right level most of the time and others running all fubar'd up.
Ok if you get a 255 pump you NEED a FPR and should get injectors...with a 16G and the fuel to use it to full ability and a good tune you can get like 350WHP. That looks like an oil feed or something the Jpipe is a pipe that bolts on to the turbo and runs like a J from the Compressor housing to the intercooler basically it ia a lower IC pipe but on a 2G you need it a 1G you dont
ORIGINAL: agallardo
Is the GT28R turbo any good? Any of you guys recommend this turbo?
Ok
So heres my proposal.... I just bought my car last week... All this stuff is being shipped as we speak... Car is stock(except loud BOV/Highflow cat)..
-3" downpipe(bought and being shipped)
-CAI(")
-Apexi N1 Muffler(")
Items highly considering...
-(16G turbo w/2g install kit)http://cgi.ebay.com/ebaymotors/EVO-3...QQcmdZViewItem
-Walbro 255 fuel pump http://cgi.ebay.com/ebaymotors/WALBR...QQcmdZViewItem
-Manual boost Controller http://cgi.ebay.com/ebaymotors/Voodo...QQcmdZViewItem
-Boost Gauge
-Fuel Injectors (450 CC) http://cgi.ebay.com/ebaymotors/450CC...QQcmdZViewItem
Anything else????? Trying to keep it under $900 give me your feedback! Im not looking for optimal performance just a step up from stock. Thanks!
-CAI(")
-Boost Gauge
you need a full exhaust not just a muffler... get a shop to custom make a 3 inch turbo cat back for ya if you didnt buy one.
your stock injectors are 450s if you want upgrade go 660s or 550s to run that fuel pump you will need a FPR
ORIGINAL: EMonz57
No, I woulndt it is a waiste of money.... and stock fuel wont be a good idea. On a 16G turbo stock fuel can run like 12psi but you wouldnt want to run any more than that, a bigger turbo I wouldnt run stock fuel at all. If you want to do it the right way from the start by fuel and get it all tuned
ORIGINAL: agallardo
