Turn Popping?
Old 09-14-2007, 01:09 AM
victim619's Avatar
Default Turn Popping?
when I turn my car pops on the passenger side. its wierd. its a 99 gs spyder. any idea on waht it is and whats needed to fix it?
Old 09-14-2007, 02:34 AM
Default RE: Turn Popping?
that popcorn sound is ur cv joint my friend
Old 09-14-2007, 03:07 AM
victim619's Avatar
is it easy to replace? what is it and what does it do? and how much does the part run for?
Old 09-14-2007, 07:00 AM
The CV joint is covered by a black boot behind your rotor. Its not too difficult to replace. But what it does is keep constant velocity (CV) to the wheels from the driveshaft no matter how your turning.
Old 09-14-2007, 07:36 AM
Its possible the boot is cracked, leaking out all the grease and causing the CV to wear
Old 09-14-2007, 08:53 AM
well sebba thats most likely what happened but not he has to replace the joint at this point. There is no point in trying to only replace the boot
Old 09-14-2007, 10:06 AM
victim619's Avatar
wow that sounds bad. why in the hell would that happen though? Where can I get a good aftermarket or should I just stick with the facotry? So when i buy the joint does it come with the boot to? SHOULD I JUST LOWER MY CAR WHILE IM AT IT?
Old 09-14-2007, 10:10 AM
victim619's Avatar
wait wassent there a recall on this? http://www.mitsubishisucks.com/cars/.../10024337.html
Old 09-14-2007, 11:19 AM
bestwiseguy's Avatar
Mine did the same thing last week but on my driver side. I was told it was the Driver side axle. I figured they meant cv joint though. I cost me about 140 for parts and labor to have it fixed.
Old 09-14-2007, 11:28 AM
I think the recall is just the ball joint, not the cv joint.
Quick Reply: Turn Popping?
