Upgrades Upgrades!
I just bought for my 98 GST spyder:
1) GReddy Type-RS Blowoff Valve 2) GReddy Piping Kit 3) Turbo XS High Performance Boost Controller 4) Boost, Oil Pressure, Air Fuel Gauges 4) eBay intake (installed already) Other than that the engine is stock. What level do you think I can run the turbo at safely? |
RE: Upgrades Upgrades!
15 psi
ORIGINAL: Jeffisdecentttttt 15 psi |
how much does it run stock?
the turbo runs anywhere from 7-9 psi depending on if you have removed the bcs.
actually i think they run around 10-12psi stock. But the next thing i would do is exhaust. 3" turbo back
ORIGINAL: TheEngineer actually i think they run around 10-12psi stock. But the next thing i would do is exhaust. 3" turbo back |
ORIGINAL: EMonz57 ORIGINAL: TheEngineer actually i think they run around 10-12psi stock. But the next thing i would do is exhaust. 3" turbo back |
9 psi(+/- 2psi) the stock fuel system can take up to 17 psi but I wouldnt recomend that because any more and boom, the pistons turn into slush. Its a safe shot to run at 15, but you can bump it up to 16 if your racing someone and you need that extra little kick but 15 is deff a safe way to go.
| All times are GMT -5. The time now is 07:17 AM. |
