Well, got the RIGHT actuator this time..
Hey guys, well i thought i was ****ed when i didnt get the evo3 actuator with the turbo. But i met up with the guy today and got it from him. Now, i put it on, but when its on, the wastegate is semi open. This is bad isn't it? So i took it back off and connected the arm first, then i tried to bolt it down, but when i bolt it down all the way, it pushes the arm down, so it causes it to open. So i just loosened one bolt and put a washer there so that it would hold back a little more. Now the wastegate is closed. Is this ok?
doesnt seem right but it might work. As long as the actuator wont bind up. You might wanna use the same washer under both bolts to make sure its pushing straight on the rod, not angled too much.
