what to buy next?
Old 08-03-2006 | 03:45 AM
thehintons06's Avatar
Default what to buy next?
i have a eclipse gsx with the following mods
Removed balance shifts
crank was balanced and blueprinted
stage 2 comp cams
Evo 3 turbo/ Ported polished w/34 mm flapper
650cc injectors
turbo timer
3" exhaust
short shifter
stage 2 cluchmasters cluch
greddt type rs blowoff valve
custom turbo piping
manual boost controller
apex SAFC 2
Frount mount intercooler
pulleys
adjustable cam gears
i have about 500$ to buy my next performance part and i dont know what i should get so tell me what performance part u think i should get next?
Old 08-03-2006 | 09:11 AM
slow420a's Avatar
Default RE: what to buy next?
I think I have seen that mod list like 5 times so far
Old 08-03-2006 | 10:57 AM
Please tell me that setup is not venting.
Old 08-03-2006 | 11:10 AM
RCJr9186's Avatar
header and down pipe will let you spool faster. an electronic boost controller may be nice (a lot of people say it's the same thing just more expensive but i've personally ridden in my friends WRS pushing 12lbs on a MBC and once he swapped it to a EBC you can easily tell a difference) port and polish the intake, or get an MSD ignition.
Old 08-03-2006 | 11:39 AM
ORIGINAL: RCJr9186
ummm not quite. there is no difference other than how you controll boost. meaning being lazy and doing it from in cab with a digital screen or the PITA way to get out and turn a screw. it does NOT change performance in any way but going from MBC to EBC
Old 08-03-2006 | 11:49 AM
I was reading that and thinkin.... wtf?
Old 08-03-2006 | 04:29 PM
RCJr9186's Avatar
well perhaps the boost was automatically adjusted higher than it was w/ the mbc b/c there was definately a difference. he said it was the same boost setting but who knows... he's not the sharpest marble in the bag
Old 08-03-2006 | 04:32 PM
ORIGINAL: RCJr9186
it had to be different because it WILL NOT make a difference in power if the boost levels stay the same
Old 08-03-2006 | 04:37 PM
RCJr9186's Avatar
egh, oh well... you already have a pretty nice engine/turbo set up... you may wanna start on suspention work and start beatin the opponents around the corners
Old 08-03-2006 | 04:56 PM
The guy is venting. Thats something to do! Get either a recirculation kit for the Greddy Type RS or just get a Greddy Type S and hook that damn pipe back up. Speaking of that... i need to do the same because the previous owner was a d-bag.
Quick Reply: what to buy next?
