-   -   At what point is the 255lph fuel pump no good? (https://mitsubishiforum.com/forum/2nd-generation-63/what-point-255lph-fuel-pump-no-good-12314/)
Sebba Jul 28, 2006 07:39 PM
Ok my question is when does the 255lph fuel pump maxed out? My friend is building a 650+hp talon and i need all the help i can get
TheEngineer Jul 28, 2006 09:04 PM
RE: At what point is the 255lph fuel pump no good?
you wont need to worry about that maxing out the 255 fuel pump.
Sebba Jul 28, 2006 09:34 PM
Even with 650+ hp?
93eclipsegsx Jul 28, 2006 09:35 PM
https://secure.buschurracing.com/cat...6e63c1ce2b20f7
or you can get this.
Sebba Jul 28, 2006 09:39 PM
Thanks dude... but that dont answer my Q. I have heard of the dual Walbro setup... does anyone know what ther max is?
*POST 1400*
patsevo8 Jul 29, 2006 12:18 AM
you absolutely do not need a dual. that's only for drag/strip racing.
TheEngineer Jul 29, 2006 12:28 AM
well the question really is does your friend have the basic 255 fuel pump or the high pressure fuel pump. If its the normal one then you may get some problems. You will basically need the high pressure one, which is what i think the one that woody posted from buchar
Sebba Jul 29, 2006 07:35 AM
Im fairly sure its the high pressure. I could be wrong.
The car WILL be a drag car running 10s very soon..... if not 9s. Thats why i asked because i have seen the dual 255 setup before.
patsevo8 Jul 29, 2006 01:21 PM
if you're drag/strip in a 10sec possibaly 9's, i'd look into an whole different set up. i'm talking a bladder or custom fuel cell with a much larger single pump. two pumps is extra weight, money, time for nothing. so i'd say no to a dual pump on a 10 or 9 sec car.
