What turbo for a 1995 GSX
Old Mar 22, 2006 | 06:39 PM
paintballproam's Avatar
Default What turbo for a 1995 GSX
What turbo should i put in my 1995 GSX. DSM Bolt On Garrett T04E Turbocharger?
Old Mar 22, 2006 | 07:48 PM
Default RE: What turbo for a 1995 GSX
depends on what you want out of the car. Big 16G is easy to install relitivly cheap and capable of around 380WHP. I mean it all depends if the car is going to be a street machine or a track car. some turbos can get you lots of lag but huge power and they are better for track than street the 16G gives you a great street turbo quick spool nicepwer
Old Mar 22, 2006 | 08:27 PM
DesolationAngel's Avatar
ORIGINAL: EMonz57
Agreed, i've found that GReddy makes a pretty good 18G TC and its relatively inexpensive. they also have a bunch of other stuff that you can add to your kit. Heres a LINK OF DOOM
Old Mar 22, 2006 | 09:09 PM
the 18G is a mitsu turbo I think..maybe Greddy just uses it as a cheaper kit from ther BB turbos.
slow420a's Avatar
gt35r
Old Mar 22, 2006 | 09:27 PM
ORIGINAL: slow420a
gt35r
with a built bottom and top then the 35r is worth it but other wise it is a waiste of money if you dont build up in order to use the turbo for what its made to do
Old Mar 22, 2006 | 09:30 PM
street machine
Old Mar 22, 2006 | 09:31 PM
this needs to be a street machine. For now, i want the most power i can without breaking my wallet. What else, other than the turbo itself would i need to do to reach say 350hp?
Old Mar 22, 2006 | 10:24 PM
ORIGINAL: paintballproam
quite a bit. 16G at least install kit FMIC, Fuel pump, inectors,FPR, SAFC or something to tune with, cams, cam gears, MBC, 3in turbo back, tubeular manifold,clutch, needed gauges and im sure there is more stuff.
Rough guess between $2-4k and with that on AWD you can prob run high 11s with it
Old Mar 22, 2006 | 10:28 PM
ouch.
