What's common for Turn signal, brake, battery lights?
Started car today after short trip, the dash brake light and battery light stay on and the turn signals and emer flashers do not work.
Brake fluid is fine, emergency brake was not set. Voltage at the battery is 14+ v when running, 12+ when off. All other lights, headlights, running lights, and brake lights are fine. There does not seem to be a fuse for turn signals, and only a 10amp(which is good) listed for emer flashers. Any ideas? Thanks rick |
RE: What's common for Turn signal, brake, battery lights?
Well for me when i got water splash on my alternator my brake light and battery light came on and off. Maybe u need a new alternator. Just a suggestion to check.
ORIGINAL: Nubiebubie_GSX Well for me when i got water splash on my alternator my brake light and battery light came on and off. Maybe u need a new alternator. Just a suggestion to check. |
take it to an auto part store and have em run a free diagnostic. they may be able to tell you why they are on and lead you to the problem
ORIGINAL: RCJr9186 take it to an auto part store and have em run a free diagnostic. they may be able to tell you why they are on and lead you to the problem |
yea I believe so. There can be codes that are on there until you have them erased even after the problem has been fixed. There are two different kind and i cant remember what they call them.
Problem solved...
Actually there was a fuse somewhere under the hood. Wasn't listed as turn signal. Don't know which one directly, the guy that replaced it wasn't there when I picked the car up. I guess next time I won't depend on labels and diagrams. |
