WHERE IS CAMSHAFT POS SENSOR!!!
Old Apr 14, 2007 | 07:16 PM
katinkid's Avatar
Default WHERE IS CAMSHAFT POS SENSOR!!!
ANYONE help. my car didn't come with a manual and i dont have a ride to get a haynes!!!
obd 2 reads!!!
camshaft positioning sensor - bank 1 circuit malfuction
so i believe i need a new camshaft pos sensor right???? or is it something else.
can anyone please look up or tell me where it is in the engine. for a 96 gst 2.0l turbo 4g63t!!! thanks for all your help.
Old Apr 14, 2007 | 10:13 PM
racerx55's Avatar
Default RE: WHERE IS CAMSHAFT POS SENSOR!!!
on the back passenger side of your valve cover, there is a round thing that is bolted on at the end of the intake cam.
Old Apr 14, 2007 | 11:40 PM
silvercoupe97's Avatar
The 2Gs have the cam sensor tucked inside the rear cam sprocket. Good luck with that bro.
Old Apr 15, 2007 | 12:17 AM
racerx55's Avatar
wonder what idiot at mitsu thought up that one.
Old Apr 15, 2007 | 01:02 AM
ORIGINAL: racerx55
but it looks so much better tucked away
Old Apr 15, 2007 | 01:09 AM
katinkid's Avatar
yah well how do i get the sprocket off without throwing anything off.
i already tried to undo the bolt and the sprocket turned. so i turned it back. hope i didnt screw anything up.
so is there a trick to get the sprocket off so i can get behind there???
wtf, whoever thought of this needs to be shot. cus now im probly gonna have to pay 500 to get it re timed.
or can i just mount the new sensor on the outside of the gear???
Old Apr 15, 2007 | 03:56 AM
racerx55's Avatar
who cares about looks, now this guy has to tear all the timing crap off his car to fix it instead of 2 bolts and a plug like the older ones., lol
idiots at mitsu....
Old Apr 15, 2007 | 07:59 AM
katinkid's Avatar
yeah well is there any way i can just take the valve cover off, unbolt the cam sprocket. and slip it out a little so i can get a wrench in there???
then just slip it back in and tighten it back up??? problem solved right?
Old Apr 15, 2007 | 08:41 AM
racerx55's Avatar
if you take that sprocket off, you gotta take the timing cover off and the motor mount and might as well replace the timing belt if its older.you gotta tear it all down and do it right, if you dont put it back in time right youll be crying about bent valves.that gets expensive real quick. i would investigate further in wiring or anything you could have done when you messed with the intake before taking all that stuff apart. find where that sensor plugs in and recheck it.
Old Apr 15, 2007 | 02:25 PM
oh_what_up's Avatar
Definately check the wiring and make sure tha harness is seated properly. If that doesn't solve the problem, you're going to have to go through the timing procedures (top dead center, timing marks, etc) and take off that sprocket. There is a place on the camshaft to hold it with a box wrench. This will keep it from moving while you're taking off the sprocket. Definately hit up vfaq or some other resource to help you with the timing when you put the sprocket back on. If you need help you can PM me. I've done the head gasket on my car as well as the timing belt on 5 different eclipse. Remember though... Check the wiring first. Good luck brother
