WHERE IS CAMSHAFT POS SENSOR!!!
Old 04-15-2007, 04:59 PM
katinkid's Avatar
Default RE: WHERE IS CAMSHAFT POS SENSOR!!!
thanks guys. im going to attempt this today by myself.
and this will be my first timing job. so hopefully i do it correctly!!!
i will most likely have a question or 2 through out the process.
and real quick. on the valve cover. do i have to buy new gaskets. or can i reuse the old ones on there. cus im short on cash!!!
Old 04-15-2007, 07:39 PM
you can reuse the old one usually, remember not to crank the valve cover bolts too tight or it'll crack, its really easy to do, i think the torque is something like 22 inch Lbs, which is just past hand tight
as far as the timing part goes you might want to have someone give you a hand thats done it before
Old 04-15-2007, 08:34 PM
katinkid's Avatar
well it doesnt matter anyway!!!
thank you mitsubishi for using cheap metal parts!!!
well when i broke the nut on the cam sprocket. the dowel/journal whatever. snaped, lol so now i need a new camshaft.
at least i got the sprocket off. lol
Old 04-15-2007, 10:46 PM
ORIGINAL: katinkid
..... oh lord.
This is gonna be one to keep following.
good luck kid.
Old 04-15-2007, 11:02 PM
katinkid's Avatar
yah!!! if i didn't make it very clear. i was a little pissed off!
on the end of the camshaft there is a dowell, to hold the cam sprocket in place.
well when i broke the bolt loose on the sprocket. the dowell snapped as well. i mean was there any other way to do it.
this would have happend to anyone. the bolt was just that tight!!!
so now i need a new camshaft, right???
how much?
or how much for someone to do it at this point???
good thing is that i got the sensor replace!!!
Old 04-16-2007, 02:08 AM
katinkid's Avatar
bump!!!
Rlopez89
07-16-2013 05:21 PM
ywill9
03-15-2006 03:54 AM
Jeffb1
10-01-2005 04:51 PM
michael49
05-16-2005 10:30 PM
Britvalencia01
05-03-2005 01:41 PM
Quick Reply: WHERE IS CAMSHAFT POS SENSOR!!!
