Where's 95 Eclipse Transmission Diagnostic connector?
6 Attachment(s)
Its a 95 Eclipse NT. Theres an OBDII port under drivers dash and also what appears to be an OBD1 port with only 4 wires in it. I know the OBDII port does NOT provide transmission codes because a trans tech near me connected his scanner and it didnt' see my transmission.
I'm supposed to be able to read transmission codes from another diagnostic connector using an analog voltmeter to read needle swings to get codes. Link here says I should have one of the two connectors at the bottom of the page either Connector 8 or 9. See attached pic. Source is here. Mitsubishi Mitsubishi Automatic Transmission - locations of the diagnostic connectors I'm not seeing either connector but found 2 similar to connector 9. I found: 1 under drivers dash and one one on the passenger side to the right of the glove box but neither is an exact match to connector 9. Any Idea where I can find connector 9 or if one of the connectors I found will work to read transmission codes? Attaching pics of what I have... |
| All times are GMT -5. The time now is 07:11 AM. |
