Wideband and SAFC
RE: Wideband and SAFC
Since it'll be in a 2G, you'll need the 2G version. If you're using a 1G ECU, that means you'll have to redo the instrument cluster to get tach, speed, sensor gauges to read correctly. So, 2G and the version is up to 2.5 now.
The motor isn't what matters, it's the ECU. The ECU controls the motor's timings..see what I'm saying bud?
