window washers
alright, i put new window washers on my hood, and i checked all the lines, and they won't squirt out. i looked in the back where the fluid goes, and i poor fluid in and it seems to run down next to my tail light, and i was just wondering if the fluid is going out somewhere, i found some water in my spare tire compartment, so i was wondering if it's going there.
RE: window washers
You may have to pull the panels out to get to the bottle, because it sounds like you have a leaking bottle. The pump may be located on the outside of the bottle, if that is so, then the seal on the pump has hardened and is causing your leak. Not to mention, the pump may be dead. Have someone pull the lever to turn it on and listen to see if you hear the pump. Also check the tubing, it may have came off.
RE: window washers
i checked the tubing and the tubing came off from a Y connector in the back, so i put it back together and presto it started working again. i think i fixed my hatchback syndrome with it too.
RE: window washers
Cool, glad you got it fixed.
Ummm, what hatchback syndrome are you speaking of btw? |
RE: window washers
it's when you get water in the tail lights or water in the trunk and the windows get moister on the inside and it takes forever to defrost it. i seen it a lot in hatchbacks since there isn't really anything blocking it from the trunk.
