00' Eclipse autostick
Old Aug 5, 2005 | 10:24 PM
Sephiroth's Avatar
Default 00' Eclipse autostick
Hi, i recently bought a 00' Eclipse GT, and has the autostick, i really dont know how to use it and dont want to mess the transmission so if anybody can give me tips and help me i would be very happy thanks.
Old Aug 8, 2005 | 02:43 AM
sunshinee's Avatar
Default RE: 00' Eclipse autostick
First off you want to switch it to the right which will then put you into the different mode. Once you press the gas the car will rev high quickly so when you get to aporx 3 - 4k rpms you want to ease off the gas quickly and move the shifter up once and get back on the gas. Do the same for every gear. You'll get the feel of it and be able to do it smoothly and quickly without even thinking. You dont need to downshift, say for instance your comming to a stoplight. The car will automatically do that. It works out nicely for going up hills because then you can down shift to take stress off the car. Hope this helps
Old Aug 8, 2005 | 04:37 PM
wicked_outlander's Avatar
awwweee the power of sportronic....just step on and shift....thats it!!!
Old Aug 9, 2005 | 02:12 AM
Sephiroth's Avatar
Great thanks. Just one more question, a friend told me i can shift to manual while the car is running is this right?? or i have to be 0mph fully stop to change to manual??
Old Aug 9, 2005 | 11:33 AM
ORIGINAL: Sephiroth
true....you can shift it while you runnin, but not in a high rev. engine though. make sure engine is not accelerating when you do this.
Old Aug 9, 2005 | 09:46 PM
vinceaton's Avatar
I have a 03 Eclipse GTS w/ sportronic. All it does is allows you to shift at a different RPM than the stock transmission. So you can pretty much just gas it and shift when you want by just tapping it forward without releasing the petal.
Vince
03 Eclipse GTS
Old Aug 9, 2005 | 09:47 PM
vinceaton's Avatar
Why can't the engine be accelerating when you shift?
Vince
03 Eclipse GTS
Old Aug 9, 2005 | 10:46 PM
Patrick's Avatar
Administrator
i have this in my RT, same engine and tranny as you eclipse guy, and i have BEATEN my autostick on the dragstrip and some autoX'ing for 3 years now, without ANY problems..*knock on wood*...you can shift up, shift down..its great, for what it is....a knee problem prevented me from buying my car in a manual, but this is a nice version of the autostick..and MUCH better than the previous chrysler version.
Old Aug 10, 2005 | 01:11 AM
ORIGINAL: vinceaton
Vince
03 Eclipse GTS
am' talkin about switchin from auto to sport gear....cant switch to sport from auto, while the foot is pounding the pedal.
Old Aug 10, 2005 | 11:30 PM
Sephiroth's Avatar
Thanks all for the info.
