2002 Eclipse GT-Turbo
I did not see a Member's Ride section, so I figured this was as a good of place as any to plop this in here.
http://www.club3g.com/forum/showthread.php?t=55498
April Issue of Turbo Magazine & High Tech Performance
ENGINE
Precision T3/T04e Turbocharger .63 A/R Hot, .60 A/R Cold
TiAl 38mm Wastegate
TurboXS H34 BOV (Recirculated)
TurboXS High Performance Manual Boost Controller
31" Front Mount Intercooler
C2D Turbo Piping
AAI Intercooler Piping
Stainless Steel Oil Lines
K&N Air Filter
Magnaflow Cat-Back Exhaust
KV85 Magnecor Wires
Zex Spark Plugs
Proflow 62mm Bored Throttle Body
Deyeme Solid Firm Front Motor Mount
Deyeme Solid Flex Side Mounts
Custom Ceramic Coated + Chrome engine dressings
3" Greddy Evo Cat Back Exhaust
GTS Plenum Swap
400cc Precision Injectors
Walboro 255lph Fuel Pump
SPAL 11" Performance Fan
EXTERIOR
Shine Street Wing w/CF Blade
Shine Street Body Kit
Grillcraft front fascia grille
TYC Black Tail Lights
Depo Black Projector Head Lights
Front Clear Corners
QuickLIFT Hood Stuts
INTERIOR
Apexi S-AFC
Greddy 60mm EGT Peak
Greddy 60mm Boost Peak
Greddy Turbo Timer
Reverse Indiglo Gauges
Blue In Dash Neons
WHEELS/SUSPENSION/Brakes
Volk Racing GT7 w/Rays lugs + centercaps
Nitto NT555 235/40/18
Suspension Techniques Anti Sway bar
Eibach Pro Springs
KYB Adjustable Struts and Shocks
Bradi x-drilled & slotted rear rotors
Retrofitted 2000 twin piston front brake calipers w/ Powerslot Rotors
Road///Race Engineering Strut Bar
Custom Rear Camber Kit
ENGINE
TiAl 38mm Wastegate
C2D Turbo Piping
K&N Air Filter
KV85 Magnecor Wires
Zex Spark Plugs
GTS Plenum Swap
EXTERIOR
Front Clear Corners
INTERIOR
Apexi S-AFC
Greddy Turbo Timer
Blue In Dash Neons
Eibach Pro Springs
ORIGINAL: Silvertooth
Wait, you mean you don't even know? Isn't that your car?
